Pro Comp is a well-known name for all truck and off-road enthusiasts. They've been producing suspension kits and components since 1992 and recently they've come up with a new product for 2019 Ram 1500 trucks - 6" Front and Rear Complete Lift Kit. When it comes to your truck's handling, look and performance, Pro Comp knows no compromises and this kit proves it in the best way. Considered to be a complete suspension solution for your Ram, designed to improve the road and tire clearance this kit also provides superior stability and handling without sacrificing on comfort. Watch our new video review to learn more about all its components, specifications and installation details.
Pro Comp® - 6" Front and Rear Complete Lift Kit at CARiD
Features:
- Does not fit Rebel model
- Fit Factory Equipped 20" wheels all Coil Spring Models
- Do not fit Air Ride Models
- Max Tire Size: 37"
- Enhanced steering geometry, reduced weight and improved turning radius
- Rear geometry correction brackets and coil spacers maintain the factory load carrying capacity
- New knuckle design helps maintain OEM operating angles of critical components
- Compatible with factory stability control system.
Click here for more Pro Comp Suspension Systems, Shocks & Lift Kits at CARiD
