New Ram 1500 Magnum 5.9 owner here.
Max78
AZ
Magnum 5.9
So I come from the Jeep world. Had a few Cherokees, Grand Cherokee, Turbo LT1 Camaro, and a nice Dodge Dakota.
My current DD has been my 5 speed 92 Cherokee, I have put WAY too much time and money into this thing but its finally at the point where I would call it perfect. . . It has a few dings here and there but its a Jeep so who cares?
That's when I realized that I needed a truck. . .
I looked at the Chevy's but I never liked the interior or exterior, but I love the LS engine and the fact people strap cheap turbos on them and manage to get crazy hp numbers out of stock components.
I looked at the Ford's, but again, I don't like the exterior of the older models but the interiors are ok. My brother-in-law paid a premium for a low mileage 99 F150, it's currently suffering from misfires and has been a lemon from day one. Then I read about the 5.4 spark plug issues. . . Still, I was willing to look at 04+ F150's.
That's when I finally found a nice clean 98 Ram 1500 with the magnum 5.9. Exterior is clean, interior is in excellent shape for its age. 170K on the clock and it drives great with no issues yet. . . It does have a transfer-case leak but that it pretty easy to fix. It has skid plates and a tow package, now I just need to find out what its equipped with. No idea if the intake plenum has been done, I'm guessing no.
I look forward to learning from you all!
My old DD
And the new DD!
whetrick1
Welcome to the forum from La ( Lower Alabama)
pacificrefugee23
Magnum 5.9
Nice truck dude. Mines the 01' 5.9 4x4. Have you noticed an issue with the air switching back and forth from defrost and a/c?
sent from an android
M
Max78
AZ
Magnum 5.9
Thanks!
I just got the build sheet for the Ram, looks like it has some nice options. I will paste it at the bottom for anyone who cares to look.
I have not had any issues with the bend doors. I'm not sure if the ram is electronic or vacuum operated blend doors. If its vacuum actuated I would check for vacuum leaks, If you have no leaks make sure that you have a vacuum reservoir of some kind (I use a glass spaghetti jar on the Jeep) or you will lose enough vacuum allowing the door to move while in the throttle. After that I would say check the connecting arm on the blend door and make sure its not just flopping around. Good luck!
Sales Code Description
R1 Premium Cloth 40/20/40 Bench Seat
K9 Camel/Tan
ADAP Light Group
ADJ Heavy Duty Service Group
AHC Trailer Tow Group
AJKP Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
AWK Travel Convenience Group
A07P #7 Engineering Development Zone
BAZP 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CGWS Next Generation Front Air Bags
CGZS Passenger Air Bag On/Off Switch
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CSRP Passenger Assist Handles
CUNP Overhead Console w/Temp & Compass
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAP Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMDP 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
EAGC All Gas Engine
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFD Rear Sliding Window
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GTSP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXM Remote Keyless Entry
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
JPV Power 8-Way Driver Seat
JRDP Power Driver Seat
KRXP BLACK - BADGE - 4 x 4, TAILGATE
KTXP BLACK - BADGE - DODGE, TAILGATE
K1XP BLACK - MOLDING - BODYSIDE PROTECTIVE
K17P Bodyside Molding
LAAP 3rd Row Seat Belt Alert
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPES Cargo Lamp
LSA Security Alarm
MBFS Bright Rear Bumper
MCTS Bright Front Bumper
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PFKA Light Driftwood Satin Glow
QFKS Light Driftwood Satin Glow
RAAC All Radio Equipped Vehicles
RBR AM/FM Compact Disc Radio
RCEP Infinity Speakers
RDDP Fixed Long Mast Antenna
SBAS Variable Assist Power Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMP Tire Carrier Winch
TYUS P245/75R16 BSW All Season Tires
TZAP Goodyear Brand Tires
WDB 16X7.0 Chrome Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
WMJS Center Hub
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
XEFP Transfer Case Skid Plate Shield
YAAS Build To U.S. Mkt. Specifications
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Welcome!!! Glad you're here
Jay
1ATony
Preferred Vendor
hemi
Welcome to the site
Tony:rockit:
fla crkr 1 ton
Palm Harbor Fla.
5.9 [360]
Welcome to the forum nice score, i love the 2nd gen body style!!!!!!! I have an 01 Sport 4 x 4 for the last 4 years and it has been a great truck, 5.9 gas engine has not let me down. I have owned nothing but 2nd gen rams since 95 when i got my first Ram Cummins dually then a 98 Cummins dually then this gas Ram could not find/afford another dually.
mmcquinn
