New to Forum - Shutter problem
RamFan215
Hello to everyone and thanks in advance for any help! Here's my ownership history: 2003 Ram 1500 4x2 quad cab currently with 117k and I've put on 8k since I purchased it. At the time of purchase I had the trans fluid/filter serviced at a transmission shop and the comments were good to go!
Overall the issues I have seem to be increasing in severity.
1) shutter from rear at take off, more pronounced when making a turn (differential??)
2) Occasional clink from rear when shifting or just before coming to a stop at downshift (U-joint??) no squeaks yet though.
3) a jerky roll when releasing the brake (before acceleration) then smoothes at acceleration (torque converter??)
4) periodic skip at highway speeds....(don't think it is the engine) probably related to the other issues
5) just developed a vibration at 60 mph (not tires....just been balanced)
6) Just has the diff oil checked and its full, but there is a slight leak on the cover....watching it
Thanks for any suggestions!
usaf2006
North Carolina
Regarding 1 and 3. Are your tires cupped? Mine sort of are and I have the same issue. Had same issue on my old truck and after rotation and some wear it was fine. My .02 :)
RonJon '06
Southern Minnesota
A lot of those symptoms sound like a bad U-joint. I know the last time I had one go out it was bad enough to produce a shudder at highway speed.
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
:welcome:
I think you need to check your differential u joints especially the rear, and if your rear differential has an limited slip unit (clutches), that could be your problem. Hope this info helps.
stevenmicheal
