New to me 01 ram 5.9 gas, need advice
Phillyrube
Flatistan
Just something I do, but get a bottle of Ospho rust treatment. Put it in a spray bottle. Wear a mask and goggles. Climb underneath and spray all the rust. When dry, hit it with black Rust-Oleum. Doesn't need to be heavy since the Ospho is a protectant.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Bounce the truck at the rear, see how those shock absorbers feel
Nice truck !
Lilhuey007
Lilhuey007
Bethlehem PA
5.9 magnum gas
Thanks for the tip, should I mask off anything before I start spraying rustolium? Anything I could hurt?
Lilhuey007
Lilhuey007
Bethlehem PA
5.9 magnum gas
My 2001 360 is growing old with my dad now, but after 330k miles, I've seen a thing or two.
Well, you didn't mention anything about the dash falling apart so I assume yours has already been replaced.
I wish the paint on mine looked as good as yours, and unless that is a new grille, I am curious how it looks so good. The "chrome" on mine wrinkled up and peeled off in the wind.
How about a foot of heater hose on the A/C condenser box drain to prevent dirt from being blown into it and eventually plugging the drain? I don't mind my feet getting wet in the shower but not when I'm driving, but that's just me.
The bottoms of the doors are known to rust out. I wonder if some Fluid Film on the inside of the doors might prevent that?
Take a look at the throttle body valve. If it's caked with carbon, some SeaFoam will clean it up. If you pour a little into the TB while it's running, you'll have smoke rings floating throughout the neighborhood, but it's supposed to clean the upper engine carbon deposits. Not too much, or you'll choke the engine out. Wait until the engine is off to wipe off the carbon with the rag.
Not perfect grille or top of truck but for 240k miles, nothing touch up paint can’t fix. I’m gonna spray grill inserts black
Spike95
Houston
I will second the suggestion of adding some hose to the a/c drain. I found a 90 degree bent one that fit on it, but any hose will help, especially if you aim it down.
If your dash is in good condition, consider yourself lucky, and proceed with caution if you decide to open it up for any reason.
When I did my plenum repair, I also replaced the water pump and timing chain set. Seemed like the natural time to do it while I already had things apart.
Is it a 2WD or 4WD? I couldn’t tell for sure by your pics.
Lilhuey007
Lilhuey007
Bethlehem PA
5.9 magnum gas
It’s a 4wd
