Three times!? You didn’t mention that little detail.
Yep, press that down arrow button three times. If you were in off-road 2 mode(OF2), you press the air suspension lower button three times to get the truck down to E/E mode- one press down from OF2 gets you to OF1, or off-road 1 mode- the difference between OF1 and OF2 is the 1 and the 2 signify one or two inches above NRH(normal ride height). Anywho, second press gets you to NRH, and third press is all the way down to the bump stops for entry/exit mode.
But sorry, it never dawned on me to mention that little detail because I figured you already knew that since you had to of pressed the up arrow three times to get your truck up to off-road 2 mode to even get it up there; or well, 2 presses of the up arrow if you were already at normal ride height.
So that will override the warning I got?
What error message did you get?? You shouldn’t have got one at all…
I really need to read the 800 page manual I downloaded. Have plenty of time for that now as the boat is back on my lift...till something breaks.
Yeah, I most certainly would. This is 2020 and, cars and pickups are pretty complex these days that it’s almost imperative that you should read the manual because there’s so much **** in there that you have no idea about it unless you read it.
Just to give you a tidbit- if you ever pull anything heavy with that truck that requires a weight distribution hitch, that manual actually tells you what mode to put your air suspension into so that you can set your hitch up and get it set up properly and still have your air suspension work normally how it’s designed to do so uh, read that book. This ain’t 1980, or even 1990 anymore to where you could just throw that book out and figure everything out for yourself.
