TheEnder
- Aug 12, 2017
- 2,088
- 1,634
- 2013
- 4.7L V8
Hello everyone,
Recently i made a thread on swapping the RFE in my truck out for the 8HP70.
I contacted russell @ SGA and he told me that since my truck is a 13 that they came from the factory with the 8HP and that the harness from them isn’t needed for the swap if i feel as though i can wire in the trans and shifter myself, but if i want it as close to factory as possible that i can get the harness from them which is the way i want to go. Harness is 1K, pretty cheap. Expected it to be 2K +.
So, i’d expect a used 8HP70 to be around the 800$ area. Factor in the mounts, new trans crossmember etc with either a 2 piece driveshaft or the OG single piece with the 8HP70 flexplate off the Hemi. I have the wiring for the shifter already in my dash, only thing needed now is the transmission wiring and everything mentioned above. Will probably run into the 2-3K range once i’m done which is again very cheap for what it is. Once i’m done selling old parts i expect to maybe if i’m lucky recoup around 1.5K. I hope this helps any other 8HP swappers in the future, any questions go ahead and ask.
