Nice!
Shaggy
Administrator/Owner
Administrator Moderator
Made it just for you as I saw you register :D
Shaggy
Administrator/Owner
Is there any talk about it?
CumminsCrazed
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
i know they dont require **** injection. Their 07.5 67 Cummins was already 2010 emissions friendly. As far as what ttheyll do, not sure.
Shaggy
Administrator/Owner
So you think they won't need to do anything to compete with ford or chevy?
CumminsCrazed
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
as fa as performance wise? not sure, but i do know dodge still has the most known and reliable diesel out there, so even if the others outperform it performance wise, at least it wont be sitting in the shop with its cab off or changing 6000 dollar injectors like the ford and chevy likely could be
Shaggy
Administrator/Owner
are you on cumminsforum as well.
You going to be here alot? If so, I will create a whole new cummins section with all the bells and whistles.
woodruff112
ya i will be on here alot if there is a cummins section.. i am on cummins forum just as much as gm-trucks.com... if there is a better cummins part of the site i will try and get a few of my buddies from cumminsforum on here too.. who knows... i know there is a few dodge sites out there and majority of them are crap. so make this one count :D
Shaggy
Administrator/Owner
Like said before, if I build it, they will come. You being on the ground floor with this site, I would like your opinions on things that need to be added here, so start making suggestions! :D
CumminsCrazed
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
4BT section, 12v ( VE and p pump) section 24v section (VP), 5.9 24v CR section (03-07), 6.7 24v Section (07.5-10)
Horns
Waterloo, Iowa
01 Chevy 3500HD
12v Cummins
That's what I think. Cummins doesn't need to do anything to compete. They have had a rock solid engine since the 90's. ;) Especially since the 6.7 already met 2010 emissions without using Urea injection.
Horns
Waterloo, Iowa
01 Chevy 3500HD
12v Cummins
Were you at Cedar Falls last night? I was looking for ya but couldn't find ya.
Shaggy
Administrator/Owner
Ok, if I create these, you will have the users here to post in them ;)
Horns
Waterloo, Iowa
01 Chevy 3500HD
12v Cummins
And of course all of those sub forums would need a couple experienced Cummins addicts to keep things under control. :rolleyes:
Shaggy
Administrator/Owner
I catch what you are tossing. :D
CumminsCrazed
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
nah i got too much i need to fix on my truck, whole front steering needs rebuilt, my t case is cracked from boosted launches in 4WD and i think i have a vacuum leak or a front brake issue.
Shaggy
Administrator/Owner
So you want me to make a section on its own for this setup?
TheM4rxxx
