kidmandudebro
Being as it looks like your 50,damn kid,lol,it might be easier to explain it like a carburator. There's 2 jets inline in both the fuel feed line and the nitrous feed line,that in a nutshell control the amount of either fuel or nitrous that flows through the spray bar, so if you install a smaller fuel jet it leans the nitrous to fuel ratio down,very similiar to if you jetted a carb with smaller jets to lean the carb down.Most kits come with jets that are set up for a very safe tune,which keeps the motor running on the rich side to prevent piston damage,so by jetting the fuel jet with a smaller inline jet,you restrict the fuel flow to the spraybar,which leans out the air/fuel ratio and in most cases will supply more power,up till you burn a piston.If you're going to play with the jetting,you'll definitely want to invest in an air/fuel ratio gauge to keep track of what your jet changes are doing to the air/fuel ratio. The old saying "lean is mean" applies to nitrous,up till you melt a piston,lol
LMAO I totally understand it better now thank you. I'm a musician too so add that to some of my confusion, I use the left side of my brain. And probably inhaled some nitrous back in the day too. LOL... seriously thanks for the breakdown it did make more sense. I think I might go get the Zex kit 10lb bottle try to jet for a 50 to 75 shot.
Then I'll save up for long tube headers and a Greene tune.
