Robert 2017 2500
Ever since I deleted my truck. I just disconnected the egr and remove the plunger. No delete kit. I have no heat. It gets hot 190. Radiator hoses get hot. I will check the heater hoses next. I will check the blend door actuator too. Do any of you think I did something under the hood. Thank you in advance. Also I heard you can zero out the egr. I have raceme tuner. Can I use that, if so how can do that with it or is there something else. I wanted the EGR deleted because its the main reason this will have premature engine failure earlier than expected.
