No kits available?
NorthCountry
Pa.
Recently purchased a 2021 Ram Warlock (all terrain package w/3:55 gears). I went with the 3.6 engine.
I recently took it in for service. I inquired that I was interested in either leveling out the truck or going with a 3 inch lift kit. Its a 3.6 engine so I am not looking to put large tires on it. I was just interested in some 33 inch, Generals ATX's. They told me since I had a 3.6 engine that there is no leveling kit or lift kit made for it. They told me the cross members are not set up for it. Has anyone else come across that information, (problem).
Elvira
Somewhere
That seems odd there is no kits available just because it is a v-6. Being careful nothing affects warranty...I am sure there must be after market manufacturers that could help with answers. Give it time here, someone will respond with a similar case and remedy no doubt.
crazykid1994
2wd or 4wd? Stock tires should be 33s already. What is the stock size it came with. Any leveling strut for 4th gens should fit. They may be stiffer since the 3.6 is a bit lighter weight but the eibach front struts would be a great option if you’re 4wd.
Edit: did research. That truck cones with a 265/70-17 which is a 31.6” diameter but also has a 1” lift stock. 33s should fit.
NorthCountry
NorthCountry
Pa.
Thank you for the response and information. Its a 4WD and does have the 1 inch lift from factory. Eibach does make great after market suspension products. I'm going to try the 33's first. Not really looking for tire width, but height, see if they rub, especially in reverse. Thanks again.
crazykid1994
I would try a 285/70-17 or 285/75-17. Ask the tire shop if they think it’ll fit but I would guess yes
Mb7640
Fountian hills az
Please let us know i was wondering if i could put 33 on my 2021 warlock without leveling.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
This is why people working on vehicles nowadays is scary. You have options and plenty of them
pacofortacos
I didn't like 285/70/17's on mine with Pa roads, wanted to kick out in the rear if you hit a bump going around a bend or stopping quickly while turning.
Stock 20's with 275/60/20 tires will give you 33" and improve your handling quite a bit and not rub.
Any lift over 2" will void your warranty or at least it used to, since mopar sold a 2" lift for the 4th gen. trucks.
