mj23polaris1
01 ram 2500 5.9 gas, put a fresh trans in it from firepunk, fluids good and it shifts good. But won't go into overdrive. Reason transmission was replaced is this truck is a off-road toy, and last time I really drove it a few years ago I turned it into a boat and had water up into the cab on the driver's side. After this incident I drove the truck home and it wouldn't go into overdrive on way home, well the fluid looked like a strawberry milkshake.
I don't think there is anything mechanically wrong with the new trans, it did sit in my garage for along time till it was put it. Does it just need drove? I had a older man tell me to try driving it and see if it would "free up"?????
Is there a ground that may be bad or something electrical I should look into? I checked the one fuse under the hood and it was good but could the relay in the fuse box be bad? I meant to get one tonight but didn't make it to store in time.
Could the trans be from a different year truck? The plugs all work but could there be something different about what the computer is reading?
I don't have any codes could it be my throttle position sensor?
Sent from my moto z3 using Tapatalk
