No overlay on Parkview image
Saxtonram
Hello
I just purchased a 2011 Ram 1500 Crew Sport. Love the truck, but am still learning how to use all its features.
Notably, I have Parkview which is a great help when I reverse with my boat. The manual shows an overlay that represents the width of the truck. It is color coded to show distance to the truck (red, yellow, green). But i do NOT have that overlay on my actual camera image. Why not? How do I turn on that overlay? I just phoned UConnect and they had no idea. Help ...
Saxtonram
stimpy433
IOWA
Is it a OEM camera or an aftermarket one??? I know the aftermarket ones usually have a white wire up by the camera that you cut if you don't want the grid lines.
I googled it and from what I read only 2011 jeeps had grid lines, ram trucks didn't. Does your truck have rear sensors that beep when you back up????
Link: http://www.ramforumz.com/archive/index.php/t-96481.html
R.L.K.
Bristol , Tn.
Not sure on the 2011 , my 14 is in the radio
My dad has an 11 , I seem to remember most of his settings being accessed on his sterringwheel buttons .
S
Saxtonram
Thanks Stimpy433
It is the original OEM backup camera system. It does have the Parksense beeping when objects are detected. Very odd that Jeeps had the grid lines, but not the Rams.
S
Saxtonram
The buttons only let me turn the rear view camera on or off.
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
There was a change in the cameras some where between 2011 and 2012 were the guide lines were included, earlier versions didn't have it.
When I upgraded my 2009 with the camera I did it around this time frame and purchased the updated camera so my rig has the guide lines.
S
Saxtonram
Interesting. So the lines are in the camera itself? Do you know anything about which model version of camera has the lines?
dRAMbuie
Sarnia, Ontario
This.
The earlier versions did not have grid lines on the display. It was actually like that on a lot of vehicles when back-up cameras were first gaining prominence.
dRAMbuie
Sarnia, Ontario
I could be mistaken, but I believe it was the 2012 and newer models.
"In the camera" meaning it's a programming feature that I assume isn't compatible with the older cameras.
Another thing to keep in mind is that there are also grid lines on newer model vehicles that turn with the steering wheel.
If you were hoping to have those as well, you may be out of luck. I'm not sure how that would work on an older model truck.
S
Saxtonram
Weird thing is the Gridlines are explained in the vehicle user manual for 2011.
