2013Ram1500base
Hey everyone, old guy here hoping someone can help me out.
2013 1500 basic with 3.6L gas.
I can't figure out why there's no power coming from the trailer hookup. Looking for the problem, I had it running, with lights turned fully on, (not just auto). F29 and F30 fuses were good, I put in new ones anyway. Still no power at the connector in back. Tried it with blinkers, flashers, every way I could think but no power. I was checking everything with a multimeter, and to make sure the meter was working I put it on the fuse box and it showed correct voltage.
So I'm thinking there's a relay somewhere, or a disconnection between the power distributor (fuse box) up front and the plug in the back. Someone said there's a harness connector somewhere behind the front wheel well, but before I tear everything open to look, does anybody have any ideas what else I can check? Do I need to replace the plug unit? How do I check if it's bad, or just not getting power?
Thanks everybody in advance.
