in short my truck was stolen in the day time...after a month, i get a call, they pulled a guy over in it, he had a warrant...so i went and drove the truck home...iam grateful and lucky...more to the story later..here is the issue. i notice that the fan only worked on hi, after looking into it he had the resistor unplugged because it got hot and melted the mounting it was in, also the dash was trashed.. he didnt know how to take it apart to put in the new heater core..but he got in installed...so i replaced the trashed, air plenum box that has the heater core, ac coil and blower motor. as well as the whole dash assy, after the complete reinstall, i replaced the blower motor and resistor,, no blower...fuse at the fuse panel is good, and the fuse under the hood is good as well as the blower relay...also new ignition switch...i did find the heated mirror wires from the push button on the dash had melted and burnt some wires i traced and seperated the ones that were stucked togeather ...here the thing if i run a hot wire a spot on the blower relay plug, fan works on all speeds, seems i lost power from some where there lies the problem..
