No Power to Trailer battery
winesalot
Chelan, WA
5.9 Cummins
I have a gooseneck trailer that has electric over hydraulic brakes. The hydraulic pump requires the 12V hot wire to work and it is not energized. I checked the 40 amp fuse under the hood and swapped the trailer power relay with the blower relay. Still no power at the truck side of the plug. Any Idea what has failed?
What triggers the relay to close?
W
winesalot
Chelan, WA
5.9 Cummins
OK, I figured out that the connection under the rear end where the stock harness terminates and the bumper/gooseneck adapter are butt connected had a corroded hot wire.
I would still love a wiring diagram for the trailer's wiring for future diagnosis.
Administrator
The trailer 7-pin +12V doesn't have a relay that energizes it, it a straight connection to the battery via the fuse.
The trailer plug light circuits do have relays, the are before fuses, you need to have the lights activated to be able to check voltage at the fuses.
If that plug for the gooseneck at the rear bumper wasn't a moulded t-tap fitting that plugs into the back of the 7-pin on the bumper, it's most likely an aftermarket setup
Tulecreeper
AZ - 83 Miles SW of the Geographical Center
Looking at the back of the truck:TruckWiringDaig.png
Agimpuraj
