Thats not family members playing the gas game, thats just family members being assholes. Who the hell borrows someones truck and brings it back with the tank empty?!
Exactly, but they seem to think because they're broke and I'm not that it's ok to inconvenience me and spend my money. Isn't family the best.
Actually your theory is partly correct.. the other reason is that fuel cools the pump so when you run it low, it actually overheats the pump.I try to fill whenever I get to 1/2 with the theory that head pressure will help the pump work less and try to never run it really low. I don't know if it really helps the pump much but at least I'm not fearing being stranded on the side of the road. After reading 29 into a 32 that was very nearly empty makes me wonder about where my 26 actually is when I sputter to a stop so anyone with a 26 chime in if you have had an experience.
Gypsy you are correct it does cool the pump which is very important but if the pump stops picking up fuel from sloshing the pump will rev up only to bog down when the fuel returns and that can't help it. Many $ to replace a pump and many reasons to keep 4 or 5 gal. in it whenever possible. I start planning to fuel when I get 1/2 and try not to see 1/4.Actually your theory is partly correct.. the other reason is that fuel cools the pump so when you run it low, it actually overheats the pump.
Sent from my SM-G903W using Tapatalk
I never able to get 32 in my HD either. WTF Dodge??So it happened
Have been getting 28 gallons into the fuel tank running 15 or 20 miles past empty. Today I was towing heavy and didn't want to get off the highway to fill up during 5 o'clock traffic.So I pushed it a little farther. I knew I wasn't getting 10 mpg probably more like 7 or 8. Ran out of fuel a few miles from where I was going to get off and filll up. Had a half gallon in a can in the back and that got me to the nearest station. So much for a 32 gallon plus reserve tank. This is what went back in.
View attachment 161542 View attachment 161543
I bet so. Bummer.Even more pitiful with a 26 gallon tank.
Sent from my SM-G920V using Tapatalk
I agree, I try to never go below 1/4.Keeping at the least a 1/4 tank will help prevent overheating of fuel pump and decrease risk of picking up any possible moisture or dirt. I mean for the sake of pulling off highway why risk an unwanted expense or possible pump breakdown on highway.
