Noise at rear of truck
aeromax4
Brookhaven, Pa
I have a 2020 1500 Laramie, no air ride. Every time I hit a bump in the road, even a small bump, I get a noise coming from the rear of the truck. I noticed the truck only has coil springs, no shocks. the springs are not broken and nothing appears to be loose. At first I thought it may be the spare tire loose but it wasn't. The sway bar seems to be tight as well. Any thoughts or recommendations on a fix? TIA.
tron67j
Maryland
You should have rear shocks as well, they are just separate, correct?
What does noise sound like? If a squeak it could be a bad bushing at a connection point or a shock is bad. If a thump, something is loose, again could be a shock or the spare could be jarred enough to shift. Try removing the spare first and see if that solves it. Check all connections in back and tighten to spec. Rear sway bar bushings could be bad and need replacement.
aeromax4
aeromax4
Brookhaven, Pa
I do have shocks and coils. Both shocks are tight. I'm now wondering if they need to be replaced. 41000 miles? I bounce the rear bed and the truck doesn't bounce, it stays tight.
aeromax4
aeromax4
Brookhaven, Pa
Thanks for responding.
aeromax4
aeromax4
Brookhaven, Pa
If you have a hitch receiver that you leave on when not towing, they can rattle/bang around a lot on bumps.
I do have the hitch but don't tow. I never put a receiver in the hitch. I'll put it up on ramps and secure with jack stands when it cools off a bit. It's not a rattle but more a clunk. Only when hitting even the slightest of bumps.
