Noise from header
jknappen
Kentucky
have afe shortys on my truck. Question is when cruising and eco mode is on everything sounds good. When its pulling a hill or accelerating it has this gurgling type sound. Not really sure how to describe it other than that. Sometimes at idle it has the sound too from both sides. Is this normal? I have checked the bolts and they are all tight. Do not feel any exhaust leaks.
Brandon-w
Yukon
2015 Ram 1500
You may just be hearing your injectors. Does the sound change from startup to normal operating temperature. Since I did my headers it's gotten loude. Almost like a chick chick noise.
Brandon-w
Yukon
2015 Ram 1500
Also in eco mode it Will sound different because it shuts down engine cylinders. If you put the transmission into manual mode it'll prevent the engine from going into eco mode.
jknappen
jknappen
Kentucky
Yea. Kind of a little. Didnt notice them with the manifolds on. If you stomp on it it goes away but under a little accleration it is louder
Brandon-w
Yukon
2015 Ram 1500
Yeah I'm definately willing to bet that's what it is. There's another thread talking about this too. No need to worry many of us are experiencing this too. As far as I know it's the nature of the beast.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
When I put headers on my 2013 it got very noisy, Very Noisy. Drove me crazy; the stock manifolds absorb a lot of noise. Not sure about the gargling noises.
jknappen
jknappen
Kentucky
It just kind of sounds like an old beater truck but not as loud. I dunno how to describe it.
jknappen
jknappen
Kentucky
Where is that thread at?
clint440
Graham WA
So other than that, how do you like the AFE shorties? Been considering them..
guru1ofatl
Atlanta, GA
Headers have a tendency to be a bit noisy due to the thin walls. If you have a tuner and can log short term fuel trims, look for variation between the banks to see if there is an exhaust leak at the flanges. Look for soot at the collector as well.
bchap05
When I got my truck brand new it had sort of a pinging or kind of sounds like metal rattling. Only happens towing up hill, or under heavy acceleration. I climbed under the truck and found that a heat shield was smashed and lightly touching under vibration. So I pried it out and it seemed to stop and I thought I had it fixed. But I've noticed it again a few times since although not as often.
I've posted about it before but didn't seem like anyone else had it. Not sure if its same noise you hear. Always run either 89 or no octane 87. Does it both ways. Does it with mds on or in 8th gear doesn't matter. I don't think its actually pinging, something rattling or vibrating once the engine hits 5k+ rpm
Brandon-w
Yukon
2015 Ram 1500
That sounds like you're describing valve float to me.
Brandon-w
Yukon
2015 Ram 1500
Look up valve float it should explain it.
RamCares
n/a
n/a
Hi bchap05,
We're sorry to hear that you are experiencing this. If you decide to work with your dealer towards a resolution, please send our team a private message. We are available via private message.
Alex
Ram Social Care Specialist
bchap05
Hi bchap05,
Alex
Thank you!
clint440
Graham WA
I like them. The drivers side is a ***** to install and tighten the bolts down.
Notice any performance or mileage gains? I know the consensus is to go long tubes but I'm hesitant to add a bunch of noise, heat, and a tight fit.
TheM4rxxx
