Todd 71
I have the same problem. It's the noise cancellation system. I took it too the dealer today. It goes away when I roll my window down. Their replacing my amp. I will keep everyone in the loop.
Replaced amp still have that noise. Driving me nuts.
Same here drove 6 1/2 hours with it yesterday and have another 6 1/2 Monday.
Mine is primarily coming from the drivers side. Is yours that way too?
No it seems to be coming from the noise cancellation system. If I roll my window down I stops. It's like bass feed back though the entire cab. If tried everything. I replace all my speakers with Kicker audio. So I'm taking them out this weekend to see if that's it..
I had enough disconnected the noise cancellation system...no more noise/bass buzz
Is this noise cancellation system the same as when your speed increases so does the radio?
Gotchya, thnx.No. A simple explanation of noise cancellation takes the ambient background noise within the cab and plays it back through the audio system at 180° out of phase with the original sound.
Theoretically the inverted sound waves should cancel each other out.
Drop the headliner and disconnect the 4 noise cancellation pins..if you dont know if that's the problem. When it starts roll down the front windows.
Directly above the driver and passenger seats in the headliner 2 on each side. I shouldn't of said pin sorry
Yes you are right I just asked my guy. Disconnect the rear ones and the second ones up front
