Mitchy
Hey everyone, I've got an 04 2500, 5.9 cummins. I recently had some humming from the rear diff (11.5 aam 3:73). After some research and messing around I came to the conclusion that my pinion bearing is on its way out. Before I fork out for a rebuild I thought I'd look for an axle to swap in. I found one from an 07. Apparently it has a "non dampened pinion" can anyone shed some light on what that means and if it would work in my 04??? Also, is anyone aware of differences in the ABS speed sensor connectors between those years and will I have issues there? Thanks a bunch in advance.
