noob lifter
norka
Im looking to get a few answers. I want to lift my truck, I have a 2011 outdoorsman, so im supposed to have heavier shocks. would i be fine with just getting the spacers or should i look at still replacing the struts in the front and coils in the back. looking at getting a 4" lift and running some 33x10.5x17
N
norka
Thanks, i havn't yet because im still babying it as ive only had it for a couple of months, but come october through winter i do. so 33's are small, 35's work for me too
The Assassin
B-more careful, Murderland
Gotcha...well few options. If you're on a budget...you could do a 3" body lift and a leveling kit. Or do the body lift and Bilstein leveling shocks.
Or..you could do a suspension lift. Zone Offroad makes a 4" and a 6" for your truck. The price difference is marginal..few hundred.
mitchman
SC
IMO level it and stuff some meats under it.
N
norka
if I just level it how big of tires can i fit under it?
txbass06
NE Texas
5.9 Magnum
35's
Sent from my iPhone 4 using Tapatalk
Musclemckeester
Houston, TX
n/a
n/a
With a 2" level kit I'm running 35s. Since yours is an Outdoorsman it's .7" taller than mine from the factory, making it even easier for you to clear 35s with just a level. If you go a 4" suspension, you'll want to run 35s. If you consider a 4" I'd say instead go with a 6" - it's only a couple hundred more. You can run 35s or 37s if you wanted to. Many that have gone with 4" have wished they had gone with a 6" - just something to keep in mind.
If you want a 4" though - look into Rancho - the back is lifted with longer struts, not blocks which I think is better. If you'll consider a 6" look into either Pro Comp or Rough Country.
Just to give you an idea, here's mine, 2" front coil spacer and 295/65R20 (35.5x12.2x20) Nitto Trail Grapplers.
Musclemckeester
Houston, TX
n/a
n/a
Here's a pic of a guys truck from another forum. He's got a 4" Rancho lift and 35s. His is a TRX so yours would sit exactly like this with a 4"
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I love that truck............first set of MG heads I did too. :D:D
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
that truck just ........ well........gives me a ******.
Musclemckeester
Houston, TX
n/a
n/a
LOL, it's not too late to lift yours. And since you bought a 4x4, I wouldn't have to question your judgement for lifting a 2wd. Come on, the sound of a $2500 lift, $1200 tires and a lost of 2 mpg doesn't sound appealing? :D
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
I ran 35” tires on my very first lift, 3” Daystar body lift.
Went right to 37” after my 6” lift on top of the 3” body lift.
I may switch around my rim sizes, but won’t go less than 37” now. Mileage sucks, but have to pay to play!
ram1500rsm
Trabuco Canyon, CA
You brought up this thread from year 2011 to let everybody know you did a 6” lift with 35’s?
