Not starting in park.
Ryan012500
I have a 2001 2500 5.9gas. For about a year the truck would sometimes start in park always start in neutral. I put a new tranny in last year that's working great no problems at all. I did switch the neutral safety switch from my old tranny when I installed it a year ago. A few weeks ago it got worse to only starting in neutral. I just did a lift and swapped out a rusty fender so I figured while I was in there I would see if I can fix this problem.i started by adjusting the linkage. Each gear shows up correctly on the gear indicator on dash. And I have replaced the neutral safety switch. Still only starts in neutral. Unplugged the battery for a while still the same. Drove it around parked it. Still only starts neutral. Looked for any damaged wires nothing. Tried tightening it down a little more. Still the same. Had my wife try to start it while I pushed it by hand as hard as I could farther towards park. Nothing it just always makes the same little click as if you try to start in reverse or drive. What else could this be? I checked all fuses I have no check engine light is there some relay maybe? The switch has three wires coming out of it and I tried testing them but I don't know what they even do. With the key on one of the three was getting power. Any help would be great starting in N is getting old.
gmwilkes
I have a similar problem. Happened after my dad noticed it wouldn't start at all. He rigged the linkage with a coat hanger and I've never fixed it bc well it still starts lol. Im curious to see what the cause could be other than linkage.
MoparMagic'00
Arkansas
5.2 Magnum
only thing i can think of is wear to the neutral safety switch
