Jim233
3.7 V-6 244,000 miles, owned since new in 9/94 Cannot get that 36mm nut on the water pump to fan shaft to break loose, even using recommended techniques. Am about to try using a torch on it but... I notice that the fan blade orientation suggests that the fan rotates to the left (when looking at it from in front of truck). This would mean rotation would be in direction of loosening the nut. Again, CCW as seen looking into the engine compartment. The shop manual notes that fan drive threads are "right hand', again suggesting that fan rotation is opposite the tightening direction.
I looked at 4 Youtube videos on water pump replacement on Rams and all of them showed removal of the nut CCW (as viewed from front, looking into engine compartment). And, yes, their fan blades were oriented like mine.
Could someone please confirm that, indeed, the nut is loosened in the CCW direction? I'm gonna get the torch and a bigger hammer...
Thank you in advance for your help,
Jim
South Texas
Jim
South Texas
