Chrisdied
- Dec 5, 2015
- 2
- 0
- 1999
- Magnum 5.9
Guys I cut my cat off , right where it goes from the headers to the original cat. Removed the cat, installed a y pipe , then 2.5 tubing back to a cherry bomb muffler that dumps to the floor right at the end of the cab. Sounds good but I'm loosing gas mileage , down to 5mpg
, I left out both o2 sensors to see how it ran. What have you guys done with the sensors ? Should I put the post cat one back in ? I saved the old tubing so I can reuse the bungs. Some info would help thanks I was getting around 10ish before , I also have 35in tires on a stick rear end I believe 3.73s or 3.55 I forget which
