OAT Coolant
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
So, I had to drain the coolant to install the Whipple, and I would like to purchase another gallon in case it needs to be topped off.
In the owners manual it calls for "10yr/150,000 mile OAT coolant"
Question is, when I drained it, it was orange in color. Every OAT coolant I see is purple. Then I read that it changes from purple to orange once it's been in use.
Can anyone verify that any OEM "OAT coolant" will work in my truck?
Thanks.
Tyler Yates
Iowa
I did a thermostat and used some generic OAT coolant from oriellys. Been about 10k miles with not a single issue. As long as its OAT it will be fine.
Hemi395
Cape Cod MA
If your truck is 2013+ is should take OAT coolant. The Mopar 10 year OAT coolant does turn a pinkish Orange color after years of heat cycles and will look very similar to HOAT.
Booms
Booms
The OG
Ocala
2015 Express
I gave the VIN to the dealership and they said it was a 10 year OAT but it was purple in color. I'm nervous, lol...
Hemi395
Cape Cod MA
Yup been there done that lol. My 2013 had essentially orange coolant draining out of it so I went back to the dealership with a sample of it and the compared it to HOAT 5 year coolant. It was a slightly different orange but I didn't want to take any chances so I did a full flush with distilled water then refilled with OAT. 2 years later the OAT I put in is that same pinkish orange color. So I'd say as long as your VIN shows OAT you're good doing a drain and fill with OAT...
Hemi395
Cape Cod MA
That's the issue, I just want to top it off, lol...
It's actually super easy to do a radiator drain and fill on our trucks. There's a valve at the bottom of the radiator on the driver's side that you can undo and a place to put a piece of hose on. Drain it out into a container and refill with new coolant/water. Never a bad idea to drain out all the crud that accumulates in the radiator every so often anyway....
Tach_tech
5.7L HEMI
The OAT coolant can look orange or purple based on age and the colour of the container that it is in. As well who was the original supplier it may be orange or purple. There was actually a TSB released about the colour issue.
The newer stuff seems to stay more purple now. If your year calls for OAT use the OAT coolant.
Booms
Booms
The OG
Ocala
2015 Express
Yes, even though the color is different, the "MS-12106" number is the same. So I'm all good, I think.
tap4154
California
3.6 V6
My 2018 coolant reservoir's white dipstick has an orange tint to it from the coolant, but when I dab some coolant onto a paper towel, it's purple, so it's OAT.
BTW who was the "genius" that decided to use the names HOAT and OAT and make them all different colors?
Probably the guy that decided having brake lines 1/2" away from the tire of a TRUCK was a good idea.
Booms
Booms
The OG
Ocala
2015 Express
So, I went to put the coolant back in yesterday, and I was filtering it and transferring it to 1 gallon jugs, it had all the colors. Pink, purplish, and orange. :rotflmao:
gofishn
Iowa
hemi 5.7L, 345 cu in
Sure it did.
Happen to see Puff the Magic Dragon too.
With that new Whipple, probably a good idea to replace old coolant with new.
heat is the Enemy,
grizzstang
Calgary, Alberta Canada
I don't think I have ever re-used coolant.
If I have gone to the effort to take it out I put new in.
Most people forget that it needs to be changed and IMO 10 years is too long.
CMSBusDriver
