OEM Backup Camera Kit
Brettc9177
Ontario
Cummins 6.7
Hey!
I did a Laramie conversion to my 2014 SLT ram 2500. It has the RA4 radio and everything works! Now I just want my backup camera. Is there a factory OEM kit to install one or anyone that makes a kit? Next best thing all the P/N’s that I would need to do this. Much appreciated to anyone that assists me with this
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi,
The Mopar kit has been discontinued. We can source the OE parts however the issue is the harness is not available, You would need to source/make a custom harness. @Mpgrimm2 Any ideas where we can direct Brett to?
- Benny
B
Brettc9177
Ontario
Cummins 6.7
I’m decent at making harnesses as I’m an electrician for work. Would we be able to get P/N’s for the connectors and pins I would need?
jawzs2
Air Force
South Jersey
Quite a bit of reading, but this thread has all the info you'll ever need.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Hi,
- Benny
Yes I can make the missing BuCam harness sections for the 13-18/19-22 classic 4th Gen trucks. It takes some legwork between myself and the customer to verify differences in each truck/what's needed but it can be done and take some time to get built
Mpgrimm2
SC
5.7L
Yep. That thread and my info in post 10 cover all details for the Mopar kit that's no longer being made.
AllMoparParts.com
- Benny
All
All
Available connector ends can be found here http://connectors.dcctools.com/home.htm
I would have to read through the thread to see which ones are needed though when I get some more time.
- Benny
Lard
If your using a digital camera(2019>) the cable can be bought for $13. It's Fakra Z type connector 16ft-20ft long if you need, at Amazon1000003343.png
