I posted this a couple times here, I found this from my original post back awhile. I got the fix, buy a #6804 8939AA for a 09-17 Dodge Challenger stainless steel clutch pedal pad Mopar OEM.I got mine on Ebay from Steve White motors Inc. for $17.70 shipped.All you have to do is pull the factory rubber pad off, take the metal cover off the new pad and snip off the little nub 2nd row down from the top, 2nd nub from left.Place the metal cover back on.Put a bolt through that hole(I ground the head round to look like the rubber nubs, then painted it black)The metal pedal in the truck has a hole drilled in it's center, put pedal on pushing bolt through hole, put on washer and nut on back side and tighten.Looks great as a set and works fine.I will post pics as soon as I can.I have step by step pics at Ramforumz site
[/IMG]
