DoughRat19
- Oct 6, 2020
- 321
- 186
- Location
- Massachusetts
- 2019 Classic
- Hemi 5.7
So I have a 2019 Classic with the black quads and I just picked up some black projectors pretty cheap locally. They are the discontinued version that are all black (no chrome around the projector). I’ve been doing some research and I saw that some people swap out the front end wiring harness for the projector version and that was the route I was gonna take (OEM harness is cheaper than a retroshop conversion harness and it would have ALL of the wiring for the projectors). Unfortunately like many things these day, the harness I need is on back order with no ETA of when it would be available.
I then decided to make my own harness and include the missing wiring that most if not all of the conversion harness you can buy online are missing. Basically each projector headlight has 9 wires where as each quad headlight has 6 wires. So I was missing 3 wires on the truck side for both lights. Fortunately I got lucky and confirmed I have the missing wiring in the large connector under the fuse box, they just terminate there. I made a harness to run the missing wiring to the headlight locations and I incorporated those wires into my conversion harness. The three missing wires for each headlight are: High Beam Headlight Relay Control, DRL Lamp Driver, Front Lighting Fault Sense. Since these are missing on the truck side, any harness you buy for this conversion will not incorporate that wiring.
Here are some photos of the process. I took apart the truck to get my measurements for the harness.
Also, big shout out to @Jimmy07! I got most of my info from a post he did on another forum.
