corneileous
- Sep 6, 2016
- 6,851
- 3,916
- Location
- Podunkyville, OK
- 2018 Ram 1500 Limited 4X4
- Hemi 5.7
Ah no, I do not have the dealership do everything for me. I have them do the fluid changes because of my drive line warranty. I have had my DODGE Ram for 11 years and 300,000 miles and not one issue with warranty claims on the engine, trans, axles and transfer case (see running list below).
- Rear end blew @ 35000 (Warranty)
- Rear pinion bearing broke - rebuilt rear end 295,000 (Warranty)
- Exhaust bolts (Warranty)
- Upper control arm and tie rods RT side
- Rt side wheel hub (Warranty)
- Rt side axle shaft (x 3) (Warranty)
- Cam broke at 160K (new cam, 8 lifters, 10 valves - Warranty)
- Rt side coil packs 140K
- Water Pump/fan clutch 140K and 275,000(Warranty)
- Trans shift solenoid 80K (Warranty)
- Pulley tensioner (Warranty)
- 3 sets of shocks
- alternator
- power steering pump
- 2 sets of lug nuts
- 6 sets of tires
- 5 sets of brake pads
- 2 sets of rotors
- 3 belts
- 11 sets of spark plugs
- 6 trans fluid changes
- 8 axle fluid changes
- 11 transfer case fluid changes
- Heater core
- AC Evap
- 2 heater solenoids
- radiator
- upper and lower radiator hoses
- 3 batteries
- antifreeze flush and change (x4)
- Rear window switch
My response to this thread is for the sole purpose of helping others understand my experiences and avoiding headaches from the dealer. If you feel you are different good for you, move on then.
Well, you did say ME in your second-to-last post so how was I to know you were all the sudden going back to addressing everybody again?
Even though this post is primarily addressed to you, this pretty much goes to everyone when I rebut what you said by saying you don’t have to let the dealership do your fluid changes just to avoid future headaches from warranty claims. There’s no rule, restriction, or limitation in warranty coverage by you doing your own maintenance unless you screw something up and try later to get warranty to fix it.
