oil deal
hankRam2015
Thanks for sharing
MN-Ram
MN
6.4L Hemi
Is Mobil 1 approved by Chrysler (MS-12633) to be used in the Ram 6.4L?
cyclepuck
2014 2500 Mega
Don't know if it's certified as a lot are not but my dealer put Mobil 1 in mine.
Sent from my SM-G928V using Tapatalk
derag2
6.4 hemi
Last I looked it was not.
GoldDot
0w-40 has been in 5qt jug for awhile now.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
No it is not but many run it anyways regardless in these 6.4's.
cash4acres
4lb pompano
6.7L,660ftLbs=G56 Manual 6 speed
12 quarts Chevron Delo, Fram Oil Filter and labor to change 6.7 Diesel $53 at Walmart!
15BlueStreak
Green Springs, OH
N/A
N/A
My dealer wants 100 bucks to change oil in my 6.4.
I will be doing it myself a friend can get me amsoil for 52 bucks for 7 qts. Not too bad really. I will have dealer rotate my tires for 15 bucks though.
lpfm1990
Newfane NY
Cummins 6.7
Been running that oil since 4K, 3 oil changes later (I do it every 3500 miles even thou monitor says 40-60% usually) and no problems yes
U&A
2016 3500 SRW
6.4 HEMI
so what would Chrysler do if you had an engine failure and were not using an oil that meets their requirements?
cant they immediately turn down the warranty work?
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
In theory, they have to prove the oil actually failed and caused the engine failure. In practice, they can get away with a blanket statement that using the non 'recommended" oil is grounds for outright denial of warranty.
Using the recommended oil at the recommended intervals and receipt/records kept minimizes this.
While the "Magnuson Moss Warranty Act" puts the impedes on the vehicle manufacturer to prove a non "recommended" oil actually caused the failure, the reality is this Federal law is not enforced but only through civil action brought by a claimant. So in reality if FCA denies outright without proof that the non recommended oil caused the failure, your only recourse is to retain counsel on your dime and sue FCA using the MMWA as your basis of claim.
U&A
2016 3500 SRW
6.4 HEMI
ok.... :bawl:
I really dont want to have to order oil when i need it but ther is NOBODY in my area that has the Pennzoil. maybe I will just go back to my Amsoil guy...even though it is about $1 more per quart. :superhack:
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
ok.... :bawl:
Yeah, it is a bit of a pain. If you do a subscription order on Amazon, can get it for about $44 for a six court case. There is also some dealers on Ebay that package a 7 quart kit and MOPAR filter for around $65 delivered.
Might also want to check you RAM dealership parts department. Some actually are pretty competitive on the relabeled Pennzoil they sell under the MOPAR label.
U&A
2016 3500 SRW
6.4 HEMI
ok ,thank you. I saw the "subscription" on Amazon, just didn't want to get stuck to anything yet. didn't know how long you HAVE to do the subscription for.
and WTH! 6 quart case on amazon? must be that the Challenger takes 6 quarts.
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
When you setup amazon subscriptions, you can set the interval for renewal in and out by however many months you think you will need it. While a little shady, you can do your first order under the cheaper price subscription plan and then cancel the subscription after your first order arrives. I do not know how many times you could get away with that but just throwing that out there.
As to 6 quart cases, that is pretty standard for many synthetics regardless of brand and weight. So you would need to either pick up an off quart somewhere or order two 6 quart cases and have the off case to fill the next case orders out.
Here is a link to one of the tailored oil change packages. A little pricey at $65 or so shipped but comes with all 7 quarts needed and an OEM filter.
0W40 Full Synthetic Pennzoil Motor Oil Filter 2014 2016 RAM 6 4 Hemi | eBay
U&A
2016 3500 SRW
6.4 HEMI
thank you sir. will look into both.
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
To bad you did not buy your 6.4 before the end of last year. AutoZone was blowing out the Pennzoil Ultra 0w-40 for $2-$4 a quart on clearance around Christmas time. I cleaned all my local AutoZone's out.
U&A
2016 3500 SRW
6.4 HEMI
cool. they don't makethe "ultra" in a 0W-40 that meets the requierments anymore.
that is really cool you got that deal. though.
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
When Pennzoil went to GTL or "Gas to Lube" formulation, the Ultra became their Ultra Platinum line. When you find any 0W-40 Ultra laying around, it is just a couple year old stock but still meets the MS-12633 spec you need. I believe even the SKU's between them are the same.
stevenmicheal
