- Apr 28, 2012
- 25,010
- 50,192
- 2010 Hemi Reg Cab 4x4
- Hemi
the 10-48 clone not recommended for ram. When you have a choice between a smaller restrictive filter that is OEM recommended or a larger less restrictive filter that was recommended on rams in the same generation just not on 2012+ rams on a engine that is known for problems lubrication it's lifters, which one would you chose? Many guys here run the 10-48 good luck with that most likely it will work out.
This has been covered, for further replies read those through search.
