Oil Filter Thread
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Heres an amsoil eao 11 cut open. The filter is 12 years old. Made in mexico even
So, is that good? I’m assuming so if it got the approval from most of those over at BITOG.
I’m still actually in search of a good oil filter to settle on. I don’t know if I want to just keep using the Wix XP or if I want to try something different. I have pretty much settled on using the mobile one extended performance for my engine oil depending on how the oil analysis report comes back for the Schaeffers 9000.
Travis8352
Houghton michigan
Yes its a good filter
That is what happens when you change your manufacturing from illinois to china? You are more dependent on the supply line. It might be the best choice, it might not, but just like everything else, we need options.
Today, Champion Laboratories maintains its American heritage and stronghold in USA manufacturing with headquarters in Albion, Illinois. In 2017, the company expanded its presence as a global supplier of quality filters by opening a facility in Shanghai, China.
I checked a couple of mine, all are a product of the usa on the filter itself. Maybe the new ones wont be? You guys that eventually get new 20-820's let us know country of origin posted on filter. Maybe the raw materials are made in china or some of the materials are made in china and they can't get them?
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
All the ones I have also say product of USA ... nice !!! muahaha !!!
tul9033
OK
I had the issue with puro and ticking, and yes it has been updated, but I don't prefer puro or wix. I only use RP 20-820 and already bought a lifetime supply. I wouldnt use blends cellulose stiffens and then as bad as wix is the wix would be better then stiffened cellulose. I would have no problem using RP cousin the Amsoil EA either, or Fram Ultra as a second option for me.
Where did you get the 20-820? Doesn't look like Amazon is carrying them.
Either way they will fit, many guys running them, or consider rp 20-500 which so far are in stock.
We have been hoarding those 20-820's since 2017, if you guys really like them as much as I do, if you get a chance, buy a case and store them.
tul9033
OK
Thanks for the info.
The XG10575 is listed as 16-28psi on fram.com, coincidentally the highest rated filter in burla's graph also.
If the xg2 is 12psi and 20-820 is 11-17psi, unless it's truly 16psi+, I'm still curious what makes the 20-820 > xg2.
XG10575 vs rp 20-820 is only $1 different so no big worry there.
Going to read more.
Here's the specs off the Fram website. RP doesn't list any dimensional or psi specs. Looks like the RP 20-500 may be be the same size as the XG10575. I've been using the XG10575 on my 2019 since new. The XG10060 is the recommended filter for the 5.7 on the Fram site.
FRAM ULTRA XG10060FRAM ULTRA XG10575FRAM ULTRA XG2
Height3.334.063.984
Inside DiameterM22x1.5M22x1.5M22x1.5
Outside Diameter32.9842.813
Anti-Drainback ValveYESYESYES
By-Pass Valve Setting9-1516-2812
Base Gasket I.D.2.452.4542.422
Base Gasket O.D.2.762.7562.813
tul9033
OK
If the RP 20-500 is a match for the Amsoil EA017 the specs are as follows, which should be a nice fit for the 5.7
Amsoil EA017
Height4.45
Inside DiameterM22-1.5
Outside Diameter2.96
By-Pass Valve Setting18-24
Base Gasket I.D.2.39
Amsoil EA017
Height4.45
So that is the 20-500 clone? Still on amazon the 20-500 is only 11.99, so that is dirt cheap and is a good option. If I didnt have to many filters in stock, I think I'd be buying a case of those.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Here's the surface area and filter size comparison I provided a year ago.........
Big Blue Hemi
Keep on keeping on
Right Coast
2012 Ram 1500 Laramie
Every place that I have checked says that the 20-500 does not fit the 2012 Ram 5.7 but don’t know why.
Threads should be the same so why are they saying it won’t fit?
corneileous
Podunkyville, OK
I’m sure the guys will correct me if I’m wrong but if memory serves me correctly, I think the reason why they don’t call for that oil filter is because of its size and the location of where it’s installed on the engine.
HEMIMANN
Minneapolis, MN
Apparently people don't like reading answers to their questions posted earlier.
I'll say it yet again - oil filter manufacturers will only publish direct exchange equivalent filter sizes - NOT larger ones.
This time I'm not repeating why, again.
