Oil Filter Thread
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
Maybe someday we will get numbers on filters that have 10k miles on them, that is what I attempt to promote. Filters that will filter better at the end of an interval then other filters, and most of that is theory. Will poly be as good as spun glass at mile 10k? My guess is spun glass filters as good at any mileage as mile 1 assuming capacity is there and oil acidicity didn't come into play. I'm not as sure with poly, it's a different type of media.
Why I said "we need our own lab". Oh wait, I'm retired, ok forget it. :crazy: :Big Laugh:
I like it, will have to take a look at it in person.
9 inches shorter then any quad, 13 inches shorter then crew cab, dropped 2 inches, I guess they rake left in on purpose for the stance. I will be looking hard after they get a couple years on their production. hemi no e torque 60k give/take.
JHoward
NW Louisiana
9 inches shorter then any quad, 13 inches shorter then crew cab, dropped 2 inches, I guess the rake left in on purpose for the stance. I will be looking hard after the get a couple years on their production. hemi no e torque 60k give/tale.
I'm also looking forward to the debut of the Dakota '27 model year? ... though, I'll take a harder look at it after all of the 'Gremlins' are ironed out.
If you are lucky they will have a Pentastar, but for sure many engines will be shiet.
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Does size matter….
Seriously though, on my 2500 mile earl change I used the Purolator Boss PBL22500 and it’s a few inches shorter than the OEM Mopar filter. Getting close to my 5k OCI and looking for some guidance. Are there any issues with a smaller capacity filter, or should I look for another brand? What about the WIX XP? It looks to be more along the same size of OEM. IMG_4779.jpegIMG_4780.jpeg
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
GeauxinUp I think most of us by now would advise to use the largest filter you can. Why? Hemi is marginally oiled due to low low idle (to save gas :rolleyes: ) and of course the lifters and cams not being properly oiled.
So - anything to keep flow restriction down while efficiency up is the answer. Which is why we want all synthetic media with the largest surface area.
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Not that in necessarily matters in regards to your point, but I have the HO Hurricane. I’ll go with the WIX XP. At least it’s a synthetic blend media. Thanks!
HEMIMANN
Minneapolis, MN
I suspect with twin turbos, low flow restriction is even more critical to keep the bearings not only lubed, but cooled.
For decades turbos were sleeve bearings, then they switched to ceramic ball bearings for lower friction but they broke from fatigue like most ceramics. So I had read they are back to sleeve bearings. Or journal bearings, if you prefer.
Therefore, synthetic oil is critical for lower friction, higher heat resistance, and flow rate is important too. Any of these newer engines are being pushed - unlike the old sloppy V8 hogs of yore.
hemihustlin
Lower Southwest Quebec
i would imagine with a motor like that (TTi6) they would have the sense to call for a euro spec 0w/5w 40?
