50pascals
Hi all,
I just did the first oil change on my truck and got the WIX 57060 filter. I was surprised it was so small and looked for an alternate unit that was larger.
I couldn't find a larger filter, but I did find the WL10290 that has identical specs, but the pressure relief valve is set higher. 22 psi instead of 12 psi.
Both are same flow rating and same micron rating.
