Mike Moseley
I have posted this several times, I repeat again Ram owners need not use 5w20 oil in there trucks, The only reason Ram does this is for CAFE Standards, I have had three Ram 1500 5.7 motors, and in all three i have used Delo 15w40 oil and the engine is much quieter and smoother the MDS has always worked perfect. I have put 188,000 miles on one 5.7 and 166,000 on one other, I tore down the 5.7 with 188,000 miles on it to see how the wear patterns were, the main and rod bearings and cam lobes showed to be almost new. Please do not believe this crap that you are told by these oil gurus or what the manual tells you, I have proved without a doubt that you are better off using real oil instead of your 5w20 water. You cannot expect water to protect a V8 motor with 400hp. It simply does not have the viscosity to protect especially in a high heat condition.
