Oil for Rebuilt Hemi 5.7L
Daw14
Just out of curiosity, what is your average highway speed ?
That’s some great mileage you are getting .
Marmay
Ontario
Me personally, after I reads many posts and really good advices here,only PUP good quality oil filter and most important, the lubaguard biotech oil treatment, and so far,so good.
Hagar1
Ontario Canada
2012 Ram 1500
Before my 5.7 decided to cr@p out, I consistently got22 to 23 mpg on highway at 100 kph. As soon as I ooed on te travel trailer, the mileage dropped in half.
I am truly puzzled because I have he lifter tick but no metal. I cut every filter with a filter cutter and use a magnetic drain plug. Cannot see any metal.
It is a frustration. No codes, no check engine light. Cod start, it behaves when cold, like you would feel from a carburetted engine with no choke. The rebuilt engine is underway although, I wonder if that will be the fix.
JHoward
Louisiana
5.7 Liter
You stated in an earlier post that you were using Castrol 5w/20 GTX Ultra clean.
Fwiw, why not change you oil strategy and use 5w/30 and LubeGard Biotech and see how your engine sounds, if that is of priority. What have you got to loose?
Hagar1
Ontario Canada
2012 Ram 1500
Thank you or the info. From my research, the oil that I use is next to mobil 1. I've been using it aong with a can of liquid moly since I bought the ruck at 56000 kilometers, it now has about 220000 kilometers. I'm suspecting a failed cam. I think these engines accumulate sludge in the oil galleries that contribute to the lifter issue . I've pulled 2 engines apart recently and both had a large build-up of sludge in the main gallery at the front of the block. The sludge build up was such that one of the main bolts tha ges through the oil gallery would not fall out. One of these engines was very clean and that sludge was not expected.
I'm going to check for bent push rods and broken springs but I doubt that the problem lies in that area. The compression is good and even. No low cylinders
Hagar1
Ontario Canada
2012 Ram 1500
I'll give tha a try. I'm in Canada so I might need to search Forte lubeguard
CanWest in Edmonton carries it,if you buy 12 they cut you a deal,but i don't know if the deal is enough to offset the shipping costs.
4th bottle down.
Hagar1
Ontario Canada
2012 Ram 1500
