Commander 06
OK so I have recently changed my oil with in the last 500 miles and on the day I changed my oil I noticed it took longer than normal for the oil to be circulated threw the engine seeing that it was making the out of oil tapping longer than normal. I shut off the engine and checked the level it was at the add even after putting the recommended amount in. I did add a half quart in re started shut off and check a second time now it read slightly over full. I have been keeping an eye on the level and depending on the day it's any where from add to slightly above full with out adding any additional oil. I always check on flat ground and let sit a few minutes after running before I checked the level. My question is what would cause oil to fluctuate that much
