Funny I did mine just 2 weeks ago.
It's actually pretty easy, and even more so if you have a 4x4 as you don't need to lift the engine like the service manual says you have to.
Here is a high level guide of what to do:
You will need 21mm, 17mm, 13mm, and 10mm Deep and shallow sockets, Impact drive, Torque drive
Drop the oil from the engine, and pull the Oil stick out about 3 or 4 inches (prevents from sticking it in your eye when you remove the pan as it stick out about that much under the engine)
Start by removing the front cross member (21mm and 17mm on my 4x4).
Remove the Transmission dust pan (2 horizontally screwed bolts from transmission side, then 2 horizontally screwed bolts from the engine side, then 4 vertically screwed similar bolts on each side of the engine)
Now you have access to all of the oil pan bolts (10mm)
The front bolts are a little trickier to access as they are above the rack and pinion and the front K member, but with patience and a smaller socket/ratchet they are easily removed.
Once you have removed all the oil pan bolts it can be pryed off by putting a wide flat screw-driver between the pan lip and the gasket.
Be advised that the gasket and Windage tray are bolted to the block so you can't remove it along with the pan, the pan needs to come off first.
Once you have remove the oil pan, go to the very front of the engine and remove the oil pick-up retaining bolt (10mm). Then, you have 3 bolts retaining the Windage Tray, 2 are together and one sit further up front alone and holds the oil pick-up. Start with the bolt holding the pick up in place, and carefully remove the oil pickup.
Remove the last 2 bolts holding the windage tray/gasket and take the gasket off. You m ay have to work a little to unstick the gasket from the block but just be careful not to mark the surface of block with a sharp tool as this may impair the sealing capabilities of the new gasket.
Clean the engine block surface with a little emery cloth or 3M scuffer to remove any rust or other residue of the old gasket that could have remained on the block.
The installation is the reverse:
Put the Gasket in place, 2 screws holding the Windage tray.
The the oil pickup (The "O" ring that comes with the oil pan gasket is for the Oil Pickup base). If you install the "O" ring and pickup hodling bolt first its a little easier.
Then the pan, the transmission dust cover, crossmember and the install is complete.
Fill up the oil, run the engine a few minutes and once it is warm rev it a little around 2000rpm to make sure the oil gets distributed everywhere.
Check the oil pressure gauge in the cab and then chack un the trauck to make sure there are no leaks from the repair you just performed.
If you have the chance and the tools, I would suggest to tap all the bolts whole and be very carefull putting the bolts back in as they can be stripped easily (trust me ont hat one...).
Hope this helps and sorry I don't have any pick of the procedure.
Good luck.
