Blackghost63
Thank you all for your response's.
I like the Amsoil filters but they only have 6 holes, like you said I don't know if it really makes a difference or not, just a mental thing I guess. Been using the Fram ultra with 8 holes plus the grippy stuff on the outside, makes a tight installation by hand a breeze.You got to love those 12 holes! For some reason I tend to stay sway from filters with only 6 holes and usually end up with 8's mostly. Probably doesn't make much difference though one way or the other. I haven't bought a K&N filter either since they moved production to Mexico several years ago either.
This is the k&n that I had that leaked. As you can see from about the 9 to 1 o'clock location it was rubbing. Center hole was not tapped square to base plate.
No, I never contacted k&n. I had read posts by other people that had and the process to get any satisfaction wasn't worth it. First it was improper installation, too loose, too tight, and the few that did, got a free oil filter. I could care less about the filter, it could have very easily cost me my motor, and their only warranty is to replace the filter. I always start mine up on the ramps and get back underneath, visually inspect for leaks plus feel around filter for any leaks. Everything looked good. In a 10 Mile round trip to work and back it had leaked 1/2 qt. I'm just glad I didn't change my oil and take off for the beach, 200 miles away. In over 50 years of changing my own oil I've only had 1 other filter leak, and it was a k&n on my Harley. Figured the second one was it, I'm done, no more k&n.You jinxed me. Got to work this morning and, lo and behold, there are TWO drips under my truck. One is A/C condensation, the other does indeed appear to be oil.
Benefits of working at a trucking company, I'm gonna wait till later this afternoon when the shop isn't as busy then pull it over the pit and see what's going on. May just need to snug up the filter, may be the issue you posted about.
Did you contact K&N about your problem? I've used their products for years and never had an issue before. If this is a case of bad design or poor QC on the filters I'm sure going to let them know. VERY disappointing from what is supposed to be a premium brand.
No, I never contacted k&n. I had read posts by other people that had and the process to get any satisfaction wasn't worth it. ... I always start mine up on the ramps and get back underneath, visually inspect for leaks plus feel around filter for any leaks. Everything looked good. In a 10 Mile round trip to work and back it had leaked 1/2 qt.
That happened before I started using redline, it was the first change after I bought the truck and it was Castrol that leaked, so no great loss there.Damn if I had leaked out a 1/2 a quart of Redline I would have been pissed six ways to Sunday.
This is the k&n that I had that leaked. As you can see from about the 9 to 1 o'clock location it was rubbing. Center hole was not tapped square to base plate. The recommended k&n filter for the hemi is made in Mexico, the larger filter that some are using is made in USA.
Sent from my XT1650 using Tapatalk
The important part is you caught it before any damage and know what to keep a lookout for.Updating for those following along at home LOL. Got under the thing and, sure enough, filter was a bit loose. Tightened it about a quarter turn then wiped everything down. Drove to the corner store and back, then let it idle about 5mins in the parking lot. Have not seen any more drips. Will keep an eye on it over the next few days and see if it happens again.
My dad taught me when i first started changing my oil in my first truck, right after you fill it with oil, get under and check for leaks. Ive done this for 23 years on ALL my vehicles and after many many oil changes and NEVER seeing a leak, ive gotten complacent i admit..... but need to get back in the habit because things happen.
I am one to obsess over things dripping from under my vehicles. I park in the same general area at the office and know every single spot on the pavement, so if something new develops during the course of the day I can dive right under there and check it out. It me a while to get used to our AC systems dripping for so long after they've been switched off, thought I had a fluid leak at first.
I wonder how many accidents in the first rain are caused by oil dripping of vehicles. The state of CA charges 50 bucks for "smog" checks but they don't check smog levels, they just make sure the equipment is hooked up. I wonder if they will ever get to what really pollutes the environment, **** dripping off suspensions on the road and then into the river.
When I first started riding a bike in the mid seventies, it was common knowledge to never ride in the center of lane as it was always slippery due to oil drips.
