DEF fluid low, don't think you have to worry about that on your Hemi lol
If it doesn't come back on I wouldn't worry about it, cluster was probably from a diesel truck.
I'm guessing rain sensing windshield wipers?
You put an Ecodiesel cluster in your HEMI powered RAM? Does it bother you that the tach only goes up to 5K where the HEMI cluster goes to 7K? and having a DEF gauge instead of a volts gauge? I'm surprised that it would work at all.
Huh. I’ve never seen a diesel cluster that didn’t have a def gauge on it. Who knew lolyou make a lot of assumption from just a light .. the tach goes to 7K and it has no def gauge.. the light that came on was probably a byproduct of the cluster programming and I would bet it is a standard light in ALL of the 7" clusters..
well then it’s definitely not a diesel cluster then and on the other hand just for the sake of conversation now because it’s not important to me one way or the other do you have the HEMI or the ECODIESEL?you make a lot of assumption from just a light .. the tach goes to 7K and it has no def gauge.. the light that came on was probably a byproduct of the cluster programming and I would bet it is a standard light in ALL of the 7" clusters..
