- Jan 17, 2016
- 19,562
- 40,482
- 14 Sport
- 5.7
Why we use catch cans - and some education for the people that repeat what they read without understanding the subject. From an engineer that also doesnt just build, but also designs endurance and sprint car engines.
Ok so in an engine, you have blowby. Even in a brand new NA engine (higher in FE engines because cylinder pressure is higher). That exhaust goes past the rings and into your crankcase a bit before it gets to the exhaust stroke. The more wear is on an engine, especially the rings, the more of this will get into the crankcase. That makes for positive pressure in there. It has to go somewhere. We use a 1 way pressure valve (PCV valve) to relieve the pressure before it starts blowing oul pan gaskets out of their seat and stuff.
Now that crank case has oil flinging everywhere, coating everything. Including the pressure valve, which is usually near the rocker galley and drainback holes. As the crank case pressure increases (with RPM or boost) the flow rate increases. Just as wind can carry a rain drop, this can carry oil mist. That oil comes up through the PCV and gets sent through a tube to your intake. If you take the hose off, you'll see oil dripping out of it. We do this because that crabk case exhaust is filthy and the EPA doesnt like it. So we send it back through the engine to sort if re-process it and burn more crap out if it for a cleaner exhaust signature. Yes this affects power a bit but youre talking like 0.1hp, very small. Unless its verry bad. And if it is, you have bigger fish to fry.
Now i shouldn't have to tell you this, but any time you pour oil into your engine's intake, thats not really good to do... along with random smoky starts being possible (not valve seal smoke, i mean little puffs and then its gone), other stuff that happens over time is carbon cakes. You know what those do. People think that because its a port injection engine that it cleans those off. Thats not how that works. It can clean the runners. Not the inside of the engine. This situation is why we have such high temp thermostats compared to traditional engines of the past. It doest need to be 210-230 degrees, it runs up there by design because that extra heat is what helps burn out the cakes. But if youve ever blow torched a carbon cake, you know thats not enough to get rid of it. It just reduces growth rate over time. Ok so we clear so far? That looses power after a while because intake and exhaust flow is affected by it.
But theres another thing that happens. That burnoff causes soot. This soot gets on your cylinder walls. That soot to our hands may feel like harmless powder. But if youve ever blown out a candle or another oil based fuel flame in pitch black and shined a flashlight at it, youll see a sparkle in there like glitter. That happens in the engine too. Know what that is? Microscopic diamonds... Yes that's a thing. Now imagine running just a drop of 10,000 grip diamond rubbing compound i your oil.... for 10 years if oil changes. What do you think will happen? Bearings, crosshatch, skirts, rings, valve guides, rocker seats, it all wears faster. It also washes that soot into your oil, thats how it gets fed to mains bearings. Thats why oil turns black, its all the same thing. But feeding oil into the intake makes *more* of it. This means oil gets dirty faster. So catch cans help keep it clean longer. Which is always nice to have, fresher oil to run on.
We use catch cans to catch that oil before it gets fed into the engine and does any of that. Its not required for an engine to run, which is why manufacturers don't put them on, unless its an exotic. Afterall why give you something that means youll buy a car 2 years after everyone else? No, ill save the money. See the mentality here? But on modern engines that cant just have a breather cap, its a good thing to have. It means your engine will stay newer longer and lose less power over time. It can also help it run better in general when its old and sensitive to stuff. In boosted engines, all of this is amplified.
