- Jan 17, 2016
- 14,044
- 24,327
- 14 Sport
- 5.7
A ton of bad information in this post.
I have a 160 thermostat in my 2014. Zero issues with heat. Helps a ton with keeping things nice and cool for higher performance tuning.
the 8 speed trucks have an internal thermostat that you CANT change therefore your truck will run at 185 degrees minimal no matter what degree thermostat you run.
get a 180, have a custom tune done and have your fan temps adjusted for the 180 thermostat.
I've ran 180/170 and a high flow Milodon 160 in mine,the 180 and 170 were perfectly fine for heater output here in Alberta,the 160 maybe not so much,lol. If you get under 0C/32F the heater is definitely lacking in heat output,the truck is just barely comfortable at those temps.One thing I did notice with the high flow 160 is a big drop in tranny and oil temps,my 8 speed runs right around 170F at 80 mph on a 75F day now,which I like,and is the biggest reason I love the high flow 160 over the the 170 and 180 t-stats I used to run in the truck,but by no stretch would I run it in the winter where it does get cold.If you live where it gets down under 32F in the winter i'd throw a 180 t-stat back in for the colder months.It's not hard to swap thermostats on the trucks,which is something you can do easily,to compensate for the difference between summer and winter air temps.You guys seem to be stuck on leaving 1 thermostat in year round,me not so much,it's not a big deal to swap thermostats for the summer and winter.I'm old enough to remember always having 2 thermostats,one for summer and one for winter,lol
