Kukailimoku
Hello.
I have an odd overheating problem.
Symptoms:
Temp fine at highway speeds.
Overheats at stop-n-go, rush hour commute traffic.
Upper radiator hose is very hot, but the top of the radiator is flat out cold. The top half of the radiator is cold.
Some additional info that may or may not be relevant:
Once in a while, maybe once a week for the past few weeks, the water pump spooges out a cup or three of coolant. I find it under the truck in the drive way. Not every day not every drive though....
Even odder still is that the reservoir is full and even though some amount of coolant has been lost, nothing is sucked out of the reservoir to replace the lost fluid.
Also, the heater (hot air in cab) takes a long long time to kick in, bit eventually does, so it's not entirely blocked, but is oddly slow to heat up (compared to normal)
Background:
Both the radiator and the water pump have been changed within the past three to six months (separate incidents though).
2005 1500 SLT 4x4 quad cab. 252,000 miles.
Ideas?
What are the usual suspects?
Many thanks.
Symptoms:
Background:
Ideas?
Many thanks.
