62Blazer
Hopefully you got it fixed. The P0456 code is for a small evaporative leak of the fuel system and can be caused by numerous different things.
I would never, ever randomly throw parts at a vehicle based on what some person at Autozone stated. No offense to anybody that works there, but from my experience most of them have very little mechanical knowledge. On top of that somebody simply reading a code and telling you start throwing parts at it should not be listened to either. I almost always look up the actual part number I need and order based on that, versus jumping through the hoops to tell them what color the car is when ordering an oil filter.
I would also hope people might consider looking at something else if the issue was not fixed after replacing the same part multiple times. Sure, you might get a bad part one time and need to replace it (just because it's new doesn't mean it's good) but getting 2 bad parts in a row is not that common.
In regards to when the code comes on, it's pretty common to have long delays in re-activation of this code after being cleared. There is a whole series of "tests", or drive cycles, that need completed prior to a light engaging. And for many codes it would have to fail multiple tests before the ECM finally triggers a check engine light.
