P1524 Questions
Bryoung11
Oklahoma
Truck threw a P1524 code and I've already swapped a new oil pressure switch and the check engine light came on again. What else could it be? Thanks in advance.
rzr6-4
nebraska
'09 2500
Have you verified that you are getting good pressure? I believe there is an O-ring that can harden and allow for weak pick up.
Daw14
South Florida
Test with and or permanently install a tee fitting and mechanical gauge .
