P2112 code
ColoBowHunter
Colorado
2006 2500 with 5.7 hemi. Driving down the road and it surge like it was running out of gas.. it would then die. I could start it right up and drive a ways and it would do the same. It died about a mile from the house. Pulled it home replaced fuel pump stillno start. Scanned it and got a P2112 bank 1 not opening. Replaced throttle body, air intake sensor, camshaft sensor, crankshaft sensor still a no go. Followed mechanics advice and sprayed fuel into the intake and still won't start. Any ideas I am a long ways from a mechanic and am stumped.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Try disconnecting your Negative Battery Post for 30 minutes
That may reset the system for enough time to get home or to a mechanic
Common Causes Of A P2112 Code Possible causes of this code may include:
Faulty throttle body
Dirty throttle plate or linkage
Faulty throttle position sensor
Defective accelerator pedal position sensor
Throttle actuator control motor is defective
Corroded or damaged connector
Faulty or damaged wiring
Faulty PCM
Common Repairs
Replacing throttle body
Cleaning throttle plate and linkage
Replacing throttle position sensor
Replacing throttle actuator control motor
Replacing accelerator pedal position sensor
Cleaning corrosion from connectors
Repairing or replacing wiring
Flashing or replacing PCM
Read more at: https://www.obd-codes.com/p2112
Copyright OBD-Codes.com
Immerge
