This is what I used...sounds like the same thing. As far as I'm concerned...junk. lasted one wash. I applied it according to the instructions on the bottle. It seemed to bead fine if you just used water, once you used soap it was gone. Then rinse with water after the soap and zero beading and slow to sheet off. Like I said, I used Adam's graphene ceramic spray coating on driver side rear door and the meguiars everywhere else. Meguiars was gone on the first wash and the Adam's was there for a year and still beading great. If it works for you great!!! Didn't for me!!
This stuff here works great and honestly is only meant as a spray on wax ... again a lot of people think they apply it correctly but they dont .... here is how I do it
First of all you have to make sure that your paint job is pretty clean, meaning there is not much contaminants on the paint/clear coat .... if your vehicles paint is dirty it is not going to stick on at all , simple as that ..
So best thing to do is the following ...
1. Wash car as normal, you can spray an iron remover of your choice to remove all contaminants
2. Rinse everything really good, if you have a foam cannon even better ....
3. Clay bar, synthetic clay bar like Mothers or your choice
4. Polish/buff .... Most of the time you will probably get away with a good and quick 1 step with any dual action polisher
5. Use a IPA solution to wipe down every single panel ... once you have done that spray the whole car with the water hose and don't dry it ...
6. Get the Meguiars Hybrid Ceramic Wax in the blue bottle and spray each panel , you don't need much, one spray is enough for a whole panel
7. After you have sprayed every panel with the Meguiars HCW, use the water hose or pressure washer and spray each panel from the bottom going up .... you want to use the pressure washer or water hose and spread it evenly throughout the car, DON'T rinse it off !!!
8. You are not ready to dry your vehicle using a new or clean microfiber towel ..... use one to dry it and spreading it evenly throughout each panel ... You "might" see some streaks but you are going to use a 2nd towel to buff it all off very similar to how you apply a "TRUE" ceramic coating ...
The longer that sits on your car without any water getting on it after you dry it the better it is going to work .... I also mix about an ounce if that in a spray bottle and use it a drying agent when I am washing any vehicle for my customers .....
So again, this stuff is not going to work on a vehicle if the paint/clear coat is not clean ... just like a true ceramic coating, it needs to be able to go into those pores to adhere, if it can't grab onto anything of course it is going to wash right off with the first wash you give it ..
You should also not use a shampoo that is not ph Neutral if you have any type of sealant, spray on wax like this one or PnS bead maker ..
