Painted Calipers... the rears this time
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Hey dudes, painted my rear calipers this time. Came out perfect, I love the look and it was definately worth it.... well that, and changing my burnt orange brake fluid lol. Nice and clear now! Here's some shots for all you picture-******.
Before
Yeah that's right, its a 2x4 suspended between two garbage cans, with wire hangers! You got somethin to say :yourself: Lol
Finished curing and reassembled
All done, ready for brake bleeds
Tadaa
Now, I just need some nicer rims to show these babies off! Definately glad I changed my brake fluid and did a thorough job bleeding my brakes. My braking has improved dramatically. Not even a slight but of sluggish'ness.
SilentRamAD
Cypress, CA
08 QCSB 2wd
287 4.7L
Looks awesome! Great job, nice and clean. Any "problems" bleeding them *wink wink* haha jk
Bad Habit
Land O Lakes
Modded 4.7l
nice glad you got it fixed up....def on my todo list as its cheap....
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
That looks awesome. What type of paint did you use?? Just regular or rustoleum?
OklaHemi
new age hemi
duplicolor makes a kit you can get at any auto parts store for 18.00 with different colors to choose from. one of my favorite exterior mods by far--cheap and easy
Danimal77
Pontiac, IL
That's guys! Yeah I used Duplicolor Red engine enamel, it's good to 500' so it works well! Im happy!
I've had the red duplicolor kit sittin' on my garage shelf for about 2 years and have yet to tackle this. Are the calipers a ***** to take apart??? The kit basically says to leave everything assembled and paint. I kinda like the idea of taking them off to get better coverage with the paint. I might do this tomorrow if it's not too involved.
Trupiano
Trupiano
Registered User
6.7L CTD
You'll need 2 cans to tackle all four calipers, but yeah it's not too hard at all. Here's a little step by step for you.
Supplies:
painters tape/masking tape
2-3 cans of brake fluid DOT 3
Sockets 11mm, 14mm, and 21mm
Ratchet
Breaker bar, or long wrench with a closed end to use as a braker bar
brake cleaner
Car wash soap
Soap bucket
bucket/pan to catch the brake fluid that will drain out of your lines
(optional) turkey baster
couple rags
place to hang calipers on to paint/dry
2 cans of duplicolor engine paint good to 500'
wirebrush/sand paper
small rubber piece/or bolt to plug up caliper drain hole
1. Jack up the truck, put her on jackstands. I used the axle for the rears, and the lower control arms for the fronts.
2. Remove the wheels, set them aside where they wont get pain spray on them.
2b. [Optional] Use the turkey baster, or a siphone and remove as much brake fluid from your reservoir as possible.
3. Loosen the 2 large bolts on each caliper with the 21mm socket. You might need the breaker bar for these two bolts, they're torqued down pretty good. (leave them threaded in a couple threads till you get the brake line removed), then remove the 2 smaller bolts with the 11mm socket.
4. Put the catch pan under the brake and remove the brake line with the 14mm socket, let it hang over the pan. It will drain fluid, but that's ok cause you'll replace it with new fluid later.
5. take the caliper off the brake, then take the two caliper pieces apart, then take the pads off, then take the two stainless steel clips off. Clean them all with brake cleaner a couple times.
6. Sand the two caliper pieces with 250-320 grit sand paper, or the wire brush. After they are sanded pretty well, put them in the soapy bucket and clean the hell out of them with the rag.
7. After they're completely dry, hang them on the hooks for painting, and put the rubber plugs/bolts or whatever in the drain hole so you dont get paint in there. Also, tape over everything rubber. Each boot, so they wont crack and leak from getting paint on them.
8. Paint 3-4-5 coats, each 10 mins apart, and dont paint for more than an hour. Real lite coats at first, then the last can be a little thicker wet coat.
9. MOST IMPORTANT! After painting them, put them in a area where they can dry without being moved, or getting dust particles on them. AND DONT TOUCH THEM!Let them dry completely/cure, might take up to 12-24 hours.
10. WHen they're fully cure, reassemble all the pieces and put them back on the truck in reverse order, and make sure every bolt is tightened TIGHT! NOTE: THE CALIPERS NEED TO BE INSTALLED SO THE BLEEDER VALVE IS ON THE TOP OF THE CALIPER. IF NOT, YOU WILL NEVER GET YOUR BRAKES FULLY BLED.
11. Put new fluid in the reservoir, and bleed each brake several times until there's no bubbles and the brake fluid comes out in a clear/clean stream.
Hope this help!
OklaHemi
new age hemi
did you put that in the diy trup?
OklaHemi
new age hemi
hell yeah help our fellow dodge ram brothern
