Painting the Grille
HemiBabe
DFW
I'm wanting to paint my stock billet grille black since the chrome looks like crap. There are rivets holding it in, my question is this:
1.) Do I take the grille out and undo all the rivets and then just re-rivet it in?
2.) Do I just tape off the outer shell and paint the grille while it's still in?
srt8dork
Louisville, KY
honestly, i feel like it would be easier just to tape it off and paint it in place rather than removing all those rivets IMO
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I'm not sure on the 04 but isn't it like one piece that is unbolted??
AWE Daniel
Banned
Those "rivets" are crazy easy to take off, just get a punch tool the right size and pop the middle piece out, and then you can reuse them when you are done.
quietpeen
2021 TRX
Hellcat
what he said. I took mine out about 4 times and reused the plastic rivets every time. I highly suggest taking them out and sanding them real good to get a surface that primer will adhere to. I had problems with the paint peeling and one of the things I didn't use was primer. It ends up being more work, but you might want to use adhesion promoter and primer and then your paint - then a clear coat. Unfortunately you can't stop chips from occurring, but you can try to lessen the extent of peeling afterward.
HemiBabe
HemiBabe
DFW
Alright, I was definitely planning on sanding it and primering it, I don't wanna do all that work for it to start chipping right away :)
I appreciate yall's help! I will try and do this tomorrow afternoon along with my lights!
:peace:
quietpeen
2021 TRX
Hellcat
Good luck
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I found some replacement plastic plugs at Lowe's in their fastener section. Good luck..
matt99
Shreveport, LA
ive taken mine apart a few times. like they said, the chips will happen. a little touch up paint and 2000 grit will fix those up pretty good.
CaliDodgeRam
California
Anyone got pics of a white truck with a black grill? Considering that as my next mod just can't see it in my head, black grill and paint the emblem white? what you guys think
quietpeen
2021 TRX
Hellcat
It would look real good with a white shell
OklaHemi
new age hemi
why not see if anyone had the blacks ones or did they not make those for the 02-05 oem? i just posted an ad on craigslist and traded my grill like yours straight across for the honecomb. good decision i think
quietpeen
2021 TRX
Hellcat
The only black grill inserts for 02-05 was the honeycomb
OklaHemi
new age hemi
cool i wasnt sure. i know my 08 had the black billet looking one
