parasitic drain
grvlpt
milton, Fl.
Typical draw down after a few days not running. Did the hegative ground cable to terminal test. Has a drain no matter what fuse is removed. Removed ALL plug In harness connectors in back of fuse panel, drain stopped. Drain return when ANY plug in connectors are inserted. Thinking there is a short out in the PCM.
shaunnz
